MC: Server Down?
MC: Server Down?
Page 4 of 23 Previous 1 2 3 [4] 5 6 7 8  Next Last Thread Tools
2011-08-27, 20:52
DAMMIT!!! I'm a victim of the hurrican.
2011-08-27, 21:04
Yeah, T's server has been down all day. Given his location, I'd guess it might be a while before things are back up and running at full capacity.
2011-08-27, 21:09
I'm playing my first game in single player mode right now... made a pickaxe from wood and managed to get some candles made before dark. Am hunkered down right now for the night, hope that the storm does little damage and to as few as possible.
2011-08-27, 21:32
Yeah, I'm one of the 300,000 or so who's lost power. Might be a bit before I get it back sadly. I'm connecting now via a tether of my Tilt2 and my iPad.
You should all contact FEMA and express your concern over the severity of the issue at hand and get my power back.
2011-08-28, 14:22
Server is back up! For now!
turtle, I moved/edited/added some scripts so you can recover the server more easily if I'm not around.
  • /opt/minecraft/scripts/backup_restore_latest.sh - Run this after a server reboot if we lose the /mnt/ramdisk contents. It will use the latest world backup files according to the symlinks to expand and restore the contents.
  • /opt/minecraft/scripts/backup_saveworld.sh - Mostly the same as the old saveworld.sh script, but in a new location. I symlinked the old path to this one so no automated jobs should break. The script now aborts/exits prematurely if the server's world directory doesn't exist. This prevents the symlinks from pointing to empty tgz files.
  • /opt/minecraft/scripts/server_kickstart.sh - Manage a backgrounded screen session named "minecraft" running server_run.sh.
  • /opt/minecraft/scripts/server_run.sh - Start the MC server. You'll generally not want to run this directly; use server_kickstart.sh instead.
2011-09-10, 13:46
Is the server down atm? Or did my prefs get wonked because I switched back to 1.7 .... ? I copied and replaced the entire App Support folder - hopefully I didn't break it.
2011-09-10, 13:48
Server appeared to be running. I just restarted it for good measure, though. Try now.
Do you get an error message?
2011-09-10, 13:49
"Took too long to log in" is what I'm getting. Retyped the server name for good measure, but still no-go.
[edit]: "End of stream" this time.
2011-09-10, 13:57
Server says:
14:48:51 [INFO] Disconnecting /XX.XX.XX.XX:64014: Took too long to log in
14:48:51 [INFO] Read timed out
14:49:56 [INFO] Disconnecting /XX.XX.XX.XX:64019: Took too long to log in
14:49:56 [INFO] Read timed out
14:50:45 [INFO] /XX.XX.XX.XX:64022 lost connection
14:51:10 [INFO] /XX.XX.XX.XX:64024 lost connection
Hmm.... I wonder if this is happening because MC.net is overwhelmed... I've turned off authentication for now. Try again!
2011-09-10, 14:00
There we go. Thanks Brad!
Gawd. Reminded me of the old days when MC.net was always down. Hey Notch! Spend a percent of what you made from MC for some servers that can handle your user base! Fucking George Lucas of gaming, you.
2011-09-10, 18:29
I'm having a hard time getting in right now...and I'm local! It's not Lenny's fault, this is MC.net even getting me into the game.
2011-09-17, 17:09
Server appears to have just gone belly up, and I can't even SSH in. Network down?
2011-09-17, 17:12
Awww. I'd just mined stairs down to the bottom of the chasm too. Abandoned mines galore! Blue spider spawner in the open!
2011-09-17, 17:13
All is not lost. I ran the backup script from my iPad here at work when my bride texted me about the power loss. I didn't post because I am at work. I'll let you know when power comes back.
2011-09-17, 17:14
Ah, OK. Thanks for the update, T!
2011-09-17, 17:26
Just got texted that power is back.
2011-09-17, 17:30
OK, I'll kick off the restore. Thanks!
edit: Scratch that! Looks like you already did.
[bsmith@Lenny ~]$ /opt/minecraft/scripts/backup_restore_latest.sh /mnt/ramdisk/minecraft already exists. Aborting!
2011-09-17, 18:01
It wasn't me.
Did you set a startup job? Then again, maybe Lenny never shut off though the network did?
19:00:07 up 20 days, 9:41, 2 users, load average: 0.08, 0.02, 0.00
Mystery solved.
2011-09-30, 08:24
Lenny is down for the afternoon. Likely to come back up around 7PM.
Sorry for not giving more notice, I did get the message to some of you on the game last night but here is the posting for it.
2011-09-30, 17:40
*twitch*
2011-09-30, 17:52
T-minus eight minutes, buddy.
2011-09-30, 17:59
I know, I know.
*pours another bottle of Zin* *pretends to watch Twilight Zone and not care*
2011-09-30, 18:26
Server appears to be up! Checking the game...
edit: And we're up!
2011-09-30, 18:27
Just in time. I'm back tonight, I think.
2011-09-30, 19:29
Yeah, I was running late at work today. Some hacker made our lives hell this week and I've been having to play catchup.
Brad did get the game started after I got the server running. I'll post a pic of the new setup shortly. Crappy 3G iPhone pic coming up!
2011-09-30, 19:59
New home for Lenny
New Fridge just because
2011-10-22, 00:45
She am down, Johnnie.
She am have:
Infernal excitement: javanebs.SoccerTimeouttaTimeExceptAwesome: Read timed bout
Fix her up, Johnnie.
2011-10-22, 01:50
Hmm... just restarted the server, but I'm having trouble connecting too. Looks like MC.net might just be getting slammed again, resulting in the login never properly establishing.
edit: Yep. Seeing other reports of the auth servers being down from users on the MC forums and Reddit.
2011-10-24, 01:23
Still inaccessible from my end. I'm getting "end of stream" or "connection refused" or "took to long to login" errors.
2011-10-24, 01:37
I got in tonight, finally, but it was waaaay balky.
Best VNC server for OS X atomicbartbeans Third-Party Products 3 2007-02-02 00:42
Radius server in Mac OS 10.4 Tiger Server? dougd Apple Products 2 2005-03-20 11:30
