MacFUSE: FUSE for the Mac!
Page 13 of 13 First Previous 9 10 11 12 [13]  Thread Tools
AhmedFaisal
2007-06-29, 12:39
Hey Guys,
I have been trying to find it in this thread but its a bit confusing. Since the packages for NTFS-3G are currently not available I installed the whole business of MacFUSE and NTFS-3G through Fink. Now, I can do all the manual mounting but that's kinda annoying. Can someone post a quick guide as to how to create an automount on startup script for OSX?
That would awesome!
Thanks,
Ahmed
koen
2007-06-29, 13:38
Hi, i also installed it using fink today, and have the same problem as Ahmed now...
Is there somebody who knows how shadowofged made his packages to accomplish this? I really need to know.
Thanks in advance,
Koen
snert67
2007-06-30, 21:17
Just spent a few hours hacking together an Applescript (my first one ever)/shell script combination to help with mounting NTFS-3g drives in OS X (running 10.4.10 atm)
Here's a little background on my project. I had a drive formatted with fat32 for moving things back and forth between my lone PC and my Macs. When the urge hit to move files around, I dusted off the external drive and fired up the "sneaker net". Then the fat32 drive died on my and the only drive I had handy was an NTFS drive that had stuff on it I couldn't lose to a reformat and I didn't have space to store it anywhere else. So, to google I went. "NTFS-3G... iiiinteresting..."
After many dangers, toils and snares ("can't mount DVDs?!!??! wtf!?!") I got it installed and running. Problem was, I wasn't particularly enjoying getting the drive ready to write to each time...
1) Plugin drive
2) Get drive id ("/dev/disk?s?")
3) Unmount volume
4) Launch Terminal
5) Run shell script to mount it
6) Write files to drive
So... I refined my script and wrote an Applescript droplet to make things a tad easier. The new way to do it...
1) Plugin drive
2) Drop drive icon on remount scriptlet in my dock
3) Write files to drive
If your NTFS drive usage habits are anything like mine, hopefully you'll find this useful.
Here's a listing of my shell script and my Applescript (saved as an App)
Shell Script:
#/bin/sh diskutil unmount $1 if [ ! -d "/Volumes/$2" ] then mkdir /Volumes/"$2" fi /sw/bin/ntfs-3g $1 /Volumes/"$2" -o default_permissions,volname="$2"
AppleScript:
property delayTime : 1 (* Whatever your "sudo" password would be *) property myPassword : "******" (* Naming modes: 1 - Static in script, 2 - Prompt, 3 - Use existing volume name *) property namingMode : 3 (* For mode #1 * ) property staticVolumeName : "External" (* This is the failover name in case a name isn't gotten *) property staticDefault : "External" property driveName : "" (* Path to your script *) property remountScript : "/bin/sh <fully qualified script path> " on open driveicon -- Get the volume name from parms set driveCount to count of driveicon -- Assume we're not gonna make it set remountDrive to 0 set remountName to staticDefault -- Make sure we only have one object if driveCount is 1 then -- Get the volume name set driveName to item 1 of driveicon as string -- Clean it up for use set driveName to findAndReplace(":", "", driveName) -- Get the device name for the shell script set deviceName to getDeviceName(driveName) -- What should we call it when we remount? set remountName to getRemountDriveName() -- Unmount the volume if required if volumeExists(driveName) then tell application "Finder" to eject disk driveName set remountDrive to 1 else display dialog driveName & ": volume not found or is unmounted already" end if -- Do it or not? if remountDrive is 1 then -- Delay just in case delay delayTime -- remount the drive do shell script remountScript & "'" & deviceName & "' '" & remountName & "'" password myPassword with administrator privileges end if else display dialog "This scriptlet works with only a single drive." buttons {"OK"} end if end open on volumeExists(volumeName) tell application "Finder" if exists (disk volumeName) then set itExists to true else set itExists to false end if end tell return itExists end volumeExists on getRemountDriveName() -- Determine drive name based on mode if namingMode is 1 then -- Static name set remName to staticVolumeName else if namingMode is 2 then -- Prompt for name display dialog "What name would like to mount the drive under" default answer "" buttons {"Ok"} set remName to (text returned of result) else if namingMode is 3 then -- Existing Name set remName to driveName end if -- Make sure there's no name clash with existing volumes (for prompted and default) if not remName is driveName then set inc to 1 repeat until (volumeExists(remName) is false) set remName to remName & "-" & inc set inc to inc + 1 end repeat end if -- Send back what we made return remName end getRemountDriveName on findAndReplace(tofind, toreplace, TheString) set ditd to text item delimiters set text item delimiters to tofind set textItems to text items of TheString set text item delimiters to toreplace if (class of TheString is string) then set res to textItems as string else -- if (class of TheString is Unicode text) then set res to textItems as Unicode text end if set text item delimiters to ditd return res end findAndReplace on getDeviceName(volumeName) set previousDelimiters to AppleScript's text item delimiters set AppleScript's text item delimiters to " " set matchingVolumes to do shell script "df | grep '/" & volumeName & "$'" set matchingVolumes to every text item of matchingVolumes if (count characters in item 1 of matchingVolumes) is greater than 10 then set lastDevicePath to item 1 of matchingVolumes end if set AppleScript's text item delimiters to previousDelimiters return lastDevicePath end getDeviceName
To use the shell script, just add the text (I used vi) to a file (in my case .mount_script.sh) and change permissions.
To use the AppleScript, cut and paste the code into the Script Editor and save it as an application.
Some notes on the Shell Script...
1) Don't forget to run chmod +x on it to make it executable. I personally hid it in my User folder with a "." in front of the name.
2) Change your parms for the ntfs-3g call to suite your purposes. I was having privilege issues until I used default_permissions. At this point I don't pretend to know the implications of using it, but I can write files with it. Good enough for now.
Some notes on the AppleScript...
1) It has three naming modes for remounting; 1: Use a hardcoded volume name, 2: Prompt for a name, 3: Use existing volume name. I started using the script initially in mode 1, but have since started using mode 3. I haven't used mode 2 more than just enough to test. I did make a half-hearted attempt to make sure volume names weren't duplicated. If you use mode 2 (for example) and use an existing volume name, it'll add a '-#' to it and keep trying til it gets one not in use.
2) I hacked together a number of examples I've found on the web to build the script. "findAndReplace" I used wholesale (http://bbs.applescript.net/viewtopic.php?id=13008).
3) I discovered (possibly even on this site) you can't make "do shell script" calls "with administrator privileges" within a tell block (in this case I had it in a tell application "finder" block). If you get the urge to revamp things, keep that in mind.
I should really put more time into error trapping but as it is I've spent hours on the whole NTFS-3G initiative. I've run chkdsk /f on my NTFS drive more times than I can count. If anyone has any tweaks that will improve it I'd be interested to see 'em.
Enjoy!
rangerz
2007-07-03, 03:22
Thank you all for helping me get this going. I have put a compiled version with help text and everything but XCode at the following URL:
http://www.mrmays.com/ntfs-3g/NTFS-OSX-PPC-10.4.zip
It goes without saying that my small contribution is all GPL and everyone should use it everywhere!
Thank you again,
Steve Mays
koen
2007-07-03, 06:11
Ahmed, i found out how to do it. I wrote a tutorial here:
http://forums.applenova.com/showthre...042#post479042
It should be quite simple to do. Let me know!
Greetings Koen
AhmedFaisal
2007-07-03, 11:19
Greetings Koen
Hey there. Works flawlessly. Thanks!!
Ahmed
Wyatt
2007-07-03, 15:42
Oh, this is fun. Macworld printed a link to NTFS-3G in the August 2007 issue (I just got it in the mail today). The only problem is, the link redirects to Shadow Of Ged's iDisk, and he's taken the file down.
Twitter: bwyatt | Xbox: @playsbadly | Instagram: @bw317
PJALM
2007-07-07, 23:21
Hi everyone...
I managed to download the DMG file for MacFUSE 0.4.0 and installed it but have no idea where to get the NTFS-3G file.
I saw someone mention they used Fink so I downloaded it and tryed to install it that way and it says no package found...
Does anyone have the DMG file for the latest version of ntfs-3g for mac os x or know how I can get it and install it?
I appreciate any help.
Thanks
backslash
2007-07-08, 05:03
...Make a plain text document with this commands inside...
i'm new with osx, so how do i create a plaintext with a *.command extension and not a *.rtf?
textedit won't let me add my own extensions...
2007-07-08, 17:21
Just change the extension of the file manually.
quantum7
Send a message via AIM to quantum7 Send a message via MSN to quantum7
2007-07-08, 19:44
Select 'Make plain text' from the 'Format' menu. Just changing the extension to .txt won't make the file a text file.
backslash
2007-07-09, 05:00
great, thx! got another problem:
how do i execute that file? i just tried the first line (unmount) and saved it as ntfs_unmount.command, then i opened it with terminal but nothing happend. everything went fine when i open the terminal itself and type the first line in it...
quantum7
2007-07-15, 20:24
backslash,
Quick answer:
open a terminal and type
chmod +x file.command
That will set a text file as executable, allowing Terminal to run it.
Long answer:
You should really look up how unix permissions work. It's great that you're starting to use the command line and I recommend finding a tutorial of some sort for an overview of using Terminal. If you have any more questions about unix or scripting rather than NTFS-3G specifically, feel free to PM me rather than posting to this discussion.
nobody2100
2007-08-04, 01:22
hi
I was wondering how I can find (using Applescript or the Terminal) what partition type a volume has?
eg. I would like to find out whether a Volume is HFS+ , NTFS etc formatted.. if I would be able to even find out whether it was mounted using ntfs-3g or without, that would be awesome!
Would appreciate any help!
thx in advance
ShadowOfGed
Travels via TARDIS
2007-08-04, 01:33
Originally Posted by nobody2100 View Post
hi
thx in advance
This isn't really the right thread for this question, but I'll answer with a few suggestions, and another question. First: do you need to do this programatically, or do you just want to check it manually?
If you're just curious what type a volume is, you can do a Get Info on the volume in Finder.
Otherwise, the best way *I* know is just to run the following on the terminal:
mount | grep '/Volumes/MyVolumeName' | sed -e 's/^.*(\([^,]*\).*/\1/g'
That will tell you the type of filesystem used to mount a given volume. If you want more info, just leave off the "| sed …" portion at the end. Hope this helps.
Apparently I call the cops when I see people litter.
mehulsutariya
2007-08-16, 00:42
Hi,
I recently bought a MAC and having the same above mentioned problem. I am not able to write data onto the NTFS external drive. I installed the MAC FUSE but couldnt find the ntfs-3g driver. I used the above given URLs but they were gving an error called unable to mount device. Can you please tell me what should I do.
Thanks,
Mehul
Firefox 2.0 for Mac: User Interface Grievances (Redux!) Brad Third-Party Products 42 2006-11-06 13:33
Stupid Mac graphics card options Luca Third-Party Products 33 2005-07-01 01:34
Games specifically for Mac Banana General Discussion 24 2005-03-28 14:03
Of All Things: PowerMac vs. Mac mini?!?!? Wraven Purchasing Advice 20 2005-01-25 21:25
Apple releases updated Power Mac G5s staph Apple Products 43 2004-06-09 13:20
