Does anybody happen to know if "heat spreaders" are the same thing as heat sinks?
I am referring to this stick by Kingston: http://www.newegg.com/Product/Produc...82E16820134084 |
If it's not the same thing, the principle is the same. All a heat sync does is move heat away from the original source through conduction and give it an easier way to be disbursed.
Come waste your time with me |
Head spreaders are usually just a thin piece of metal without the raised columns or spikes that heat sinks have.
If you look at the closer shots of the apple memory you can see the heat sinks are much beefier than the spreaders you normally see on regular memory. |
Now in lower-caseā¢!
I ordered the Mac Pro with 2GB of RAM from apple and the 7300 video card and I was wondering how much RAM should I have so that I don't have a bottleneck or whatever it is? I will be using applications like Quark, Aperture, maybe FCP, and other standard applications. Thanks in advance for the help!
In order to see whether you need more memory, use the free MenuMeters tool and enable the memory indicators (there are multiple, for this test you want "Show paging activity" from the memory section). This will occasionally come on. Should it frequently go on or even stay on while you work (app gets stuck), you need more memory. Otherwise you dont. |
I was concerned about the size of the heatsinks on some of the aftermarket ram but -
http://www.barefeats.com/image06/owc_heat.jpg - showing ram from owc alongside Apple's ram. Looks good in red ! |
Going Strange...
Yeah - I wasn't pushing owc over anyone else's brand.
I was interested in what the difference was between a heat spreader and heat sink and what it meant in size. The barefeats pic shows how big the spreaders are. newegg are still listing crucial ram which conforms to spec - as well as Kingston. Where did you see that Crucial have pulled out ? Last edited by RobM : 2006-08-15 at 02:25. |
Going Strange...
aha - thanks guys.
The plot sickens - I think I'll take your advice, Engine Joe, and wait a little. Keep your eye on barefeats, I'm sure Rob will test some of the aftermarket Ram for heat, fan noise and performance. cheers |
A friend of mine is going to buy a Mac Pro. Is there any problem if he adds 2 x 1gb to the 2 x 512 that the machine includes? Because he doesnt have more money to buy more ram than 2 extra modules...
Does anyone know if this will work with the mac pro?
http://www.newegg.com/Product/Produc...82E16820211012 |
From what I could gather at the manufactures web site the RAM in question is unbuffered. |
No, but this will.
http://www.newegg.com/Product/Produc...82E16820134084 You need a FB-DIMM. Not a regular 240 pin DIMM, but a super expensive FB-DIMM. Look for server memory, because thats generally what it's called. MacBook Pro 15"/2.2GHz C2D/120GB/2GB |
My Predictions for the Mac in 2006 | Robo | Speculation and Rumors | 89 | 2006-09-07 06:25 |
Mac Book Pro and Verizon Internet? | FireMurphy | Apple Products | 4 | 2006-05-12 12:31 |
Installing Ram - Mac Book Pro - DIY? | faust | Genius Bar | 1 | 2006-04-10 16:06 |
Could we see the ATI FireGL V7350 in the Mac Pro? | macsforever | Speculation and Rumors | 17 | 2006-03-27 19:43 |
Same RAM on Crucial.com cheaper when buying from Mac? | usurp | General Discussion | 6 | 2004-08-22 12:04 |
