Stallion
Why would a mobo last any longer than a processor? With sockets, fsb, etc changing, I doubt in 4 years you'll still be running games at a high res on the hardware you are buying.
If you're a gamer you'd be better off buying and selling a lot, buying midrange stuff, selling it a week or two before better stuff comes out, then rebuying it. It's all about timing. |
Thunderbolt, fuck yeah!
So many bad case suggestions in here. That Antec case is such overkill and has been universally panned in reviews.
can't read
Kraetos, did you ever decide on what you were going to get? just wondering
it won't be overkill when I'm running an R600... and all I've read is good reviews(V1.1) |
I am very much leaning towards the Nine Hundred, mostly because of the 200mm fan. I don't like loud computers.
It's done! I finished it today!
The final configuration: - Core 2 Duo E6600, 2.4 GHz overclocked to 2.65 GHz - MSI P6N SLi-ready motherboard - 2 GB Corsair XMS DDR2 RAM - XFX nVidia GeForce 7900GS w/ 256 MB VRAM - Corsair 620-watt super efficient SLi-ready PSU - Zalman CPSU9500 heatsink (the thing is the size of a small bowling ball) - WD Caviar 250 GB 7200RPM HD - Sony DVD-ROM drive With an Antec Nine Hundred case and a 20" Acer LCD. We had a bit of a scare when we realized that the Zalman heatsink needed to be braced against the back of the mobo, which we had already screwed in. So we had to take the whole damn thing out again and screw the heatsink brace on. Once we got that fixed, it was very straightforward. The thing runs REALLY cool. Between the 200mm fan, the Zalman heatsink, and the Arctic Silver paste I used, it tops out at about 35˚C! The air coming out of all the fans but the top one is ice cold. It's certainly louder than the Mac Pro, but its a lot quieter than my old Alienware Aurora. If the noise ends up being a problem, I'll just start swapping out fans, but I don't think that it will be. Anyway, it runs FEAR maxed out, max resolution, 30+ FPS. I'd say that the construction of this gaming rig was a success! Pictures to follow sometime this weekend when I get my camera back. Logic, logic, logic. Logic is the beginning of wisdom, Valeris, not the end. |
Formerly “adambrennan”
Very nice. Glad to hear you got things sorted.
I've done the same thing before with a heatsink, it's quite annoying, but in my experience Zalman coolers have been the way to go. |
Not fond of the Nine Hundred at all...It's 100% overkill and pretty ugly to boot. If I were to buy a case today it would be the Antec P182 based on looks, and I'd probably only use two of the 120mm fans in it.
I'd also replace the fans with the lowest RPM S-Flex fans. |
can't read
lol the 900 is an awesome case. But I will agree with the P182 statement, but I wouldn't change anything about it. I'm thinking of buying a Rosewill lol I know they aren't supposed to be that good but when I upgrade my PC, I don't want to just do nothing with my parts, might as well put them into another comp. Anyways, here it is:
http://www.newegg.com/Product/Produc...82E16811147033 |
I do like the Nine Hundred. It's a little cramped but I like the heavy-duty industrial look (on my PC, anyway) and the LED lights are cool as well.
As for the fans, they are a little loud, and I may replace a few. The loudest is by far the Zalman fan, and I can ratchet that one down when I am not overclocking or otherwise taxing the CPU/GPU through MSI's mobo utility. I can drop it to 2000 RPM and when I do, the machine is not unnecessarily loud. For my purposes, which are pretty much 100% gaming, the Nine Hundred works very well. Logic, logic, logic. Logic is the beginning of wisdom, Valeris, not the end. |
Formerly turtle2472 Join Date: Mar 2005
Bump!
Instead of starting a thread this seems to be the best place to put my question. I need to replace a case fan and I need it to be silent but effective. I don't really care about the price and I don't want it to be made to glow with LEDs. I had an 80mm fan in it and replaced it with a thermal control 92mm fan (largest my case will support). Problem is that it emits a high pitch whine and it's driving my wife and me nuts. It's for my server that is in the living room so I just want it quiet. I'm not overclocking or anything like that. In fact I'm sure the Athlon 64 just about never hits half CPU load in the server. After losing my PSU and replacing it with a slightly more powerful one, case cooling might be part of the problem due to the case location. Putting a larger fan in seems like it'll help airflow that much more. Thanks for any help. Louis L'Amour, “To make democracy work, we must be a nation of participants, not simply observers. One who does not vote has no right to complain.” Visit our archived Minecraft world! | Maybe someday I'll proof read, until then deal with it. |
Most people go overboard with fans. How many do you have right now?
The most widely available quiet 80mm fans out are the Panaflo line. They're legendary, but no longer the quietest fans on the market. You should probably look at Nexus or Scythe/S-Flex if you want the quietest out there. |
Hmm, just helped my friend put together a beast.
3Ghz Core 2 Duo (E6850) ASUS Maximus Formula LGA775 4GB RAM EVGA E-GEFORCE 8800GTS KO ACS3 PCI-E 580MHZ 640MB 1.7GHZ GDDR3 320GB WD + 80GB from old PC 500W PSU DVD+RW (Double Layer) Antec Sonata III Black ATX 16IN Mid Tower Quiet Case Vista 64bit Home Premium/XP Home (on old drive) Fast and quiet, you hardly even know the thing is on, standing right next to it. |
can't read
I would go with Scythe
Can't you crank down the fan speed using a bios setting? I'd keep the big fan and slow the sucker down.
Only one case fan. It's not a beast by any means and I'm certainly not going overboard. I do agree with your sentiment for the most part though. Thanks for the input. Quote:
I have removed the fan this morning though. It was $15 at CompUSA so it isn't a great loss, just an annoying inconvenience. The case in the picture is what my case looks like. The one on the left is the same case but with my Media Center in it (P4 3GHz, Vista Ultimate). Louis L'Amour, “To make democracy work, we must be a nation of participants, not simply observers. One who does not vote has no right to complain.” Visit our archived Minecraft world! | Maybe someday I'll proof read, until then deal with it. |
No, he just got it two weeks ago, just before the new model came out. I would have said to wait if I knew an upgrade was coming like the new GT.
Ooh... let us know how noisy it is. My Windows box is whisper quiet with a passively-cooled 76GT. I'm very much tempted by an 88GT, but not if it's going to be too noisy.
http://www.zipzoomfly.com/jsp/Produc...tCode=10007134 I always told myself I'd never go back to a PC, but after losing the hard drive my work MBP this week, I decided it was time to re-separate my personal and work computing. Since my computing at home is primarily games, I decided to build a cheap gaming desktop (~$500) with the 88GT as the base. I'm so excited to see how good Gears of War, Unreal Tournament 3 and the Crysis demo look on the new machine. |
Ninja Editor
Could, but he doesn't even know about the GT. He's a gamer, but not a spec whore, so he most likely wont even care
I ordered all my components except my graphics card last night. The card is still out of stock, so I'm going to build the machine without it, using onboard graphics, on Thursday. That way, when the card gets here (hopefully early next week, if they're back in stock soon), I can just install it and go.
I have been set on building a gaming PC in November (for the new graphics cards - which turned out to mean "8800GT") since July, but now I feel like there's too great a backlog of "must do" things to go through with it. Money's tight too. I can afford a computer but I can't afford a computer sitting unused. Maybe I'll push the build to before holidays.
PB PM, your friend doesn't need to be a spec whore to appreciate the $100 difference in the "price" spec... |
Yeah, the store only takes returns on defective units, via straight up exchange so no go anyway.
My CPU is supposed to be coming today (AMD Athlon 64 X2 4000+), and the rest of my components (other than my video card) are coming tomorrow. Zipzoomfly still doesn't have the card in stock, so I'm just sitting on my hands at this point.
I've signed up for e-mail alerts at several e-mail addresses for when it comes back in stock, but I'm worried I won't be able to make my order quickly enough if it pops up while I'm in a meeting or something. This card is going to be pretty tough to get for a while. The markup on eBay is huge, too, so I can't really go that route. I'm really hoping I can get it by Thanksgiving, but I'm starting to have my doubts. |
Page 2 of 4 Previous 1 [2] 3 4 Next |
Industrial fire destroys South St. Paul building | Windowsrookie | AppleOutsider | 4 | 2006-10-11 22:51 |
Recommendation for Web Building Software | pilot1129 | Third-Party Products | 9 | 2006-03-08 23:00 |
Building binaries | torifile | Programmer's Nook | 5 | 2006-02-13 23:14 |
Building a SATA RAID | 709 | General Discussion | 2 | 2005-02-08 15:07 |
Building a PC....that's right. | Akumulator | General Discussion | 20 | 2004-11-10 11:26 |
