View Poll Results: How do you say "OS X"? | |||
Oh Es Ten | 102 | 57.30% | |
Oh Es Ex | 76 | 42.70% | |
Voters: 178. You may not vote on this poll |
EDIT: Oh yeah. I just remembered that the Fiat Cinquecento is called simply the 500 by English speakers. So I guess you could translate it. Whatever. But yeah. The fact that people who work for Apple (including The Big Steve himself) call it "Oh Es Ten" should be enough to tell you the right way of pronouncing it. People will still get the point if you say "Oh Es Ecks" but it is not correct (even if a few people think it is). It's like writing "alot" or misusing apostrophes. People will still understand, but that doesn't make it any more correct. |
From day 1 (for those of us outside Apple) at WWDC 98 it has been "Mac OS 10", specially as it was spoken of before it was seen in print. And originally the big question was "why is Apple was skipping Mac OS 9?" Quote:
Had they stayed with how they were originally releasing versions, then 10.0 would have been 10.0, 10.1 would have been 10.1, 10.2 would have been 10.5, 10.3 would have been 11.0, 10.4 would have been 11.5 and 10.5 would be 12.0. And Apple isn't the first company to change it's version numbering... Sun change Solaris 2.7 to Solaris 7. And Solaris 8, 9 and 10 are actually Solaris 2.8, 2.9 and 2.10. Don't be expecting version 11.x from Apple anytime in the near future... not as long as Apple thinks that the name "Mac OS X" has legs. |
However, there are instances when one should pronounce it as 'oh es eks' one way or the other, e.g. www.apple.com/macosx.
awesome Join Date: Jul 2004
If Apple went from OS X -> OS XI right away, it would be a comparatively miniscule change. It's almost as if they consider System 1 - OS 9 as point releases for the original Mac OS, in the same way Tiger, Leopard, etc. are for OS X. And you're right - there was also a lot of branding for OS X. The "X" logo has effectively replaced the original MacOS logo. and i guess i've known it all along / the truth is, you have to be soft to be strong |
is the next Chiquita
The version changes has been anything but consistent.
System 7 was pretty much System 6 expanded. System 8 and 9 was a major update with support for stuff then some more. System 10 is essentially a new OS from grounds up. Incidentally, where is the System 1-5? Almost nobody knows what it was; and wouldn't have recongized it if it hit them on the face. (I'm thinking that Apple ][ used System 3 or something like that). The same can be said about Windows; we went from Windows to Windows 3.1 to Windows 95/98/Me then Win XP and now Windows Vista. There's also Windows Workgroup which later become Windows NT before merging with XP. |
Eh, I'd say there were at least two distinctive versions of the classic OS. Systems 1-4 were all single-task only. System 5 introduced MultiFinder (run multiple applications at once) as an option, with System 6 being released very soon after. I'd say 1-6 qualify as one version. 7-9 are the next version, with always-on multitasking, improved graphics technology, and a huge number of other changes from the earlier versions. OS 8 and 9 were basically just rehashes of system 7, with improvements comparable to one or two OS X point releases.
I think the reason Apple's keeping the OS X name for so long is because they might want to get away from the old idea that their previous "major OS releases" were really just rehashes. The underlying OS in 10.4 is very similar to what it was in 10.0, but there have obviously been a lot of improvements since then. The same applies to Systems 7-9 - the underlying code remained basically the same, although there were still a lot of more superficial changes from one version to the next. EDIT: Banana, 7 was radically different from 6. It was almost as different as OS X was from OS 9. 6 was pretty much an advanced version of versions 1-5. 1-5 came out pretty quickly and without much fanfare. 5 introduced MultiFinder, but 6 came out not long after and replaced it, so that's the one people remember. Another interesting fact is that when Apple was working on what is now known as OS 8, the working title was OS 7.7. That's how similar 8 was to 7.6. When their next generation OS (Copland) was delayed, they changed it to OS 8 to keep it fresh. The same thing happened with OS 9, whose original working title was OS 8.7. OS 9 is even more similar to OS 8 than 8 was to 7, but all three versions were pretty much the same at the core. |
I pronounce OS X as Oh-Es-Ex and X-Men as Ten-Men.
There. |
Right Honourable Member
To add to Luca's post, I believe that OS 9 was so called in order that OS X could be called OS X without skipping 9, despite the fact that the similarities between OS 8 and OS 9 didn't particularly merit a new version number.
Thanks, Luca!
Yeah, I knew OS 7 (called System 7 then, right?) was a pretty huge jump. I just meant that, in general, the classic OSes (1-6, and, as you mention, 8 and 9) are more akin to point releases than what we would now consider entirely different versions. and i guess i've known it all along / the truth is, you have to be soft to be strong |
Hmm- Interesting. I seem to recall thinking to myself that System 7 wasn't all that different from System 6, and that System 8 was a noticable difference. I've always thought System 7 as more stable compared to System 8.
But I'm probably wrong, so I'll take your word for it. Thanks for the stories, Luca. |
Hey where the white women at?
25 chars of wasted space.
Of course going by your logic if you said that the person would end up with 'wwwdotappledotcomslashmacosx' If you are going to be a literal jackass, you can't pick and choose. |
On Pacific time
I used OS 9 at work, so it never occurred to me to say anything but OS ten. If someone were to say OS Ex to me, it would probably take me a second before I realized to what they were referring. *shrug* |
As for what the old Apples (not Macs) used... I don't know all the details but I know Apple had an old OS called Apple DOS. There were others, too, I think. |
Or maybe "doubleudoubleudoubleudotappledotcomslashmacos x"
I am worthless beyond hope. Join Date: Jul 2004
Put an option for "both", and I'll vote. Between the two, I do say "oh ess ten" more often, though, while PC-using friends say "oh ess ex" most of the time.
Windows NT was based on OS/2 (codeveloped with IBM) and was originally to be released as OS/2 NT. Microsoft change this to Windows NT and released the first version, Windows NT 3.1, at about the same time as Windows 3.1. This release was followed by Windows NT 3.5. Windows NT 3.1 and 3.5 (and 3.51) all used the same GUI as Windows 3.x. Windows NT 4.0 was released in 1996 and used the same GUI as Windows 95. Windows 2000 was actually Windows NT 5.0 and Windows XP is actually Windows NT 5.1. Windows 2003 Server is actually Windows NT 5.2. Hopefully that puts the whole Windows versions into perspective. I also have every version of Windows from 1.0 to 2000 Professional. Quote:
Stallion
o-sex ftw
HerrDEUTSCH™
I know "Oh Es Ten" is the proper way to say OS X but until OS XI/OS 11 comes out I'm going to refer to it as "Oh Es Ex".
Why? Because us "dimwits" can EDIT: I entered the Mac World after OS X came out. this message was brought to you by MrENGLISH™ WARNING: may contain Sarcasm and/or Bad Spelling Last edited by MrENGLISH™ : 2006-05-22 at 04:03. |
"Oxy Four Point Ex"
my own code~ |
Formerly “theelmerguy”
It is clear to me that the majority of people who say "10" used Macs before the switch to OS X. The people who say "Ex" entered the Mac world after the switch. Why can't we jsut coexist? Veterans, love the babies! Babies, respect the veterans!
I really don't think it is a big deal. However, I must say that ever since I learned that "10" is what Steve Jobs says, I've been more self-conscious about whether I say "10" or "Ex" (I used to/kinda still say "Ex" but I am trying to change because Steve Jobs says "10"). (As you probably noticed, I am a recent and HAPPY switcher who is just damn glad to be using Mac OS X [whatever it's called!]) |
It's certainly not worth falling out over.. You are right theelmerguy.
But I have been using Macs since the IIci and IIfx days and still prefer to say "ex", in my head at least... This is the strange thing.. We did a sort of (unscientific) test here today. I said OS X out loud and then said it in my head.. In my head I say "exx", out loud I say "Ten". 'Remember, measure life by the moments that take your breath away, not by how many breaths you take' Extreme Sports Cafe | ESC's blog | scratt's blog | @thescratt |
When OS X premiered, I'd sometimes refer to it as "Mac OS [Ex]". Then afterwards, I just made it a habit of saying "Mac OS [Ten]".
Oh Eh Sex
What about Switchers and people new to Apple? It's perfectly understandable for them to think it's pronounced Oh Ess Ex due (as mentioned before) to lots of references to Mac OS X 10.4. Plus, they might not realise there were nine previous versions of the OS before the current revision and therefore it's natural they'd read the 'X' as a letter and not as a numeral.
Just for the poll, I read it as Ex, but say it as Ten. Helvetica is my bitch. System: 27" iMac i7, 2TB, 8GB RAM, Mac OS X Snow Leopard |
There is also the before hinted at but worth repeating matter that OS "Ex" sounds more exciting than "Ten". It's the 'X' factor that OS X brings to Operating Systems, and so on... Macs are mysterious to most people, and therefore 'X' is quite suitable.. I am sure that nuance is not lost on the Apple maketting bods.
The big X on the OS boxes also tends to emphasise the "X" as an "X" and not a 10.. 'Remember, measure life by the moments that take your breath away, not by how many breaths you take' Extreme Sports Cafe | ESC's blog | scratt's blog | @thescratt |
This reminds me of Racer X from SpeedRacer
should we call him Racer Ten or Racer Decem |
Page 2 of 5 Previous 1 [2] 3 4 5 Next |
