What's the Best Business Card Software
elvia
2005-08-09, 21:43
I'm ready to make new New Business Cards. I have read about Belight Business Card Composer. Does anyone have it. Pros and Cons? What do you think is the best for the Mac
intlplby
2005-08-10, 10:18
Adobe InDesign.....
Mac+
9" monochrome
2005-08-10, 10:55
Chronos - the folks that make StickyBrain (which was offered to .Mac members at a reduced rate) have a SOHO business card package for US$29.95.
This might be a cheap and viable solution for you. Check it out!
[EDIT] I should add that I have not used this product so do not know whether or not it is the best ... merely offering it as an alternative to consider.
octavist13
2005-08-10, 12:24
Adobe Indesign, Illustrator or Quark would be your best bet, but a little pricey.
elvia
2005-08-10, 14:32
thanks for the replys. I didn't realize adobe can make business cards
I have CS2, so I should have everything I need already. Thanks
intlplby
2005-08-10, 18:49
anything made for professional printwork is best.... i'm sure if you can supply and indesign or quark file it is much easier for the print shop.... all they got to do it make it propagate it so it prints many on one sheet and added printers marks
indesign also allows you to package the design in a pdf with the font include so the print shop doesn't need to have it
atomicbartbeans
reticulating your mom
Send a message via AIM to atomicbartbeans
2005-08-10, 20:57
*cough* Appleworks *cough*
It's free with your Mac, and it has card templates.
Res
2005-08-10, 21:35
I usually use Adobe Illustrator for business cards. Are you sending a file to a print shop, or are you printing your own?
sunrain
2005-08-10, 21:50
Well, it's not like there's a set template that comes with InDesign or Illustrator (that I'm aware of), but most people who own those programs generally have the skills to make their own templates. They're blank slate programs, that's what makes them so powerful to use. I'm sure you'd be able to do a quick search and find the templates you need, if building a template is out of your skill set.
"What a computer is to me is it's the most remarkable tool that we've ever come up with, and it's the equivalent of a bicycle for our minds."
- Steve Jobs
2005-08-10, 21:50
Not if you have a Power Mac or a PowerBook.
elvia
2005-08-15, 10:01
Yes I discovered that adobe is pretty daunting if you don't know how to use it, and I don't. So, I guess I'll look and see if there are any plug-ins for templates. I suppose I will eventually learn how to do it, but there certainly is a learning curve.
Business ID cards and Management Software zman2005 Genius Bar 0 2005-05-18 15:22
Using External Wireless Card with PowerBook Joe Genius Bar 0 2005-04-30 15:48
New PowerMac graphics card available - GeForce 6800GT DDL Luca Apple Products 4 2004-11-05 16:39
Software Update and Developer Certificates Defiant Apple Products 1 2004-05-27 13:09
