I need to hand in my iBook for repair and do not want the repair staff to have access to my personal data such as iTunes library, word documents, movies etc.
Apple recommends to back up all data (that's a no-brainer, of course), de-authorise iTunes and disable firewalls before sending computers for repairs. Any recommendations on this issue would be greatly appreciated. Thanks. iBook 12" 1.33GHz G4 1GB 60GB OS X 10.4.11, iPod Nano 8GB 2G, Canon Ixus Digital 40 |
File Vault your account, then make a temporary account for them to use.
Nobody bumps my lock
Of course if they're replacing the hard drive, the point is moot.
owner for sale by house
The best idea would be to back up the entire disk (using SuperDuper! or Carbon Copy Cloner), wipe it and install a vanilla system. If you're paranoid, you can do a safe erase of all your data before reinstalling. That is the most amount of work, but it also makes sure that your data won't be seen by anybody and that you will be able to restore it to the exact state it is in now when you get it back.
Thanks a lot for your replies....two of my keyboard keys are no longer working, they probably just replace the keyboard. So I think I go with the simpler option of filefaulting my account. Cheers.
iBook 12" 1.33GHz G4 1GB 60GB OS X 10.4.11, iPod Nano 8GB 2G, Canon Ixus Digital 40 Last edited by scubaski : 2008-04-27 at 15:33. |
I did some reading up on FileVault. As it turns out I would need a lot of free space on my HD to run it (equal size as the Home folder), which I do not have.
If I just create a temp account (with admin rights) for them to use would that be ok or would they be able (with these admin rights) to override the password for my account? A more dramatic solution: I could just delete my Home folder (after backing up to external HD of course) but then I would have everything in just one place which makes me a bit nervous in case the external HD malfunctions. At the end of the day I just want to make sure that all my info is not sitting there waiting to be harvested. If I can make it inconvenient for the potential thief he might go elsewhere for easier pickings. I am not looking for a 100% tight security. iBook 12" 1.33GHz G4 1GB 60GB OS X 10.4.11, iPod Nano 8GB 2G, Canon Ixus Digital 40 |
Ok, my iTunes Library takes almost 30GB (HD 60GB) so I will move the whole lot and FileVault the rest.
One more thing I do not quite understand with FileVault. I need to set a Master Password which gives the Admimistrator full control over ALL accounts, even if he doesn't know their passwords. If I then give the repairteam admin rights does that mean they also need or have access to the Master Password? iBook 12" 1.33GHz G4 1GB 60GB OS X 10.4.11, iPod Nano 8GB 2G, Canon Ixus Digital 40 |
The Jell-o iBook | Luca | AppleOutsider | 20 | 2006-02-01 20:22 |
Intel iBook in Jan...? | scratt | Speculation and Rumors | 395 | 2006-01-08 21:57 |
trasnfering back-up HD of old ibook to a new ibook? | waiting to be enlightened | Genius Bar | 4 | 2005-05-08 10:45 |
iBook battery - down for the count? | rachel | Genius Bar | 2 | 2005-04-26 16:23 |
iBook Logic Board Questions | Stone Of Love | Genius Bar | 4 | 2004-12-09 16:11 |
