MC: Server Down?
MC: Server Down?
Page 19 of 23 First Previous 15 16 17 18 [19] 20 21 22 23  Next Thread Tools
2014-04-09, 19:18
Anything to do with the Heartbleed issue?
https://mojang.com/2014/04/heartbleed/
2014-04-09, 19:34
Likely it's due to a coding change they made on their end.
Logs for those interested in seeing it take a big dump all over itself:
[20:30:19] [User Authenticator #57/WARN]: Exception in thread "User Authenticator #57" [20:30:19] [User Authenticator #57/WARN]: java.lang.NoSuchMethodError: sun.security.internal.spec.TlsRsaPremasterSecretParameterSpec.getEncodedSecret()[B [20:30:19] [User Authenticator #57/WARN]: at com.sun.crypto.provider.TlsRsaPremasterSecretGenerator.engineGenerateKey(TlsRsaPremasterSecretGenerator.java:76) [20:30:19] [User Authenticator #57/WARN]: at javax.crypto.KeyGenerator.generateKey(KeyGenerator.java:516) [20:30:19] [User Authenticator #57/WARN]: at sun.security.ssl.RSAClientKeyExchange.<init>(RSAClientKeyExchange.java:110) [20:30:19] [User Authenticator #57/WARN]: at sun.security.ssl.ClientHandshaker.serverHelloDone(ClientHandshaker.java:706) [20:30:19] [User Authenticator #57/WARN]: at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:231) [20:30:19] [User Authenticator #57/WARN]: at sun.security.ssl.Handshaker.processLoop(Handshaker.java:609) [20:30:19] [User Authenticator #57/WARN]: at sun.security.ssl.Handshaker.process_record(Handshaker.java:545) [20:30:19] [User Authenticator #57/WARN]: at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:963) [20:30:19] [User Authenticator #57/WARN]: at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1208) [20:30:19] [User Authenticator #57/WARN]: at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1235) [20:30:19] [User Authenticator #57/WARN]: at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1219) [20:30:19] [User Authenticator #57/WARN]: at sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsClient.java:440) [20:30:19] [User Authenticator #57/WARN]: at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:185) [20:30:19] [User Authenticator #57/WARN]: at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1139) [20:30:19] [User Authenticator #57/WARN]: at sun.net.www.protocol.https.HttpsURLConnectionImpl.getInputStream(HttpsURLConnectionImpl.java:254) [20:30:19] [User Authenticator #57/WARN]: at net.minecraft.util.com.mojang.authlib.HttpAuthenticationService.performGetRequest(HttpAuthenticationService.java:126) [20:30:19] [User Authenticator #57/WARN]: at net.minecraft.util.com.mojang.authlib.yggdrasil.YggdrasilAuthenticationService.makeRequest(YggdrasilAuthenticationService.java:41) [20:30:19] [User Authenticator #57/WARN]: at net.minecraft.util.com.mojang.authlib.yggdrasil.YggdrasilMinecraftSessionService.hasJoinedServer(YggdrasilMinecraftSessionService.java:45) [20:30:19] [User Authenticator #57/WARN]: at net.minecraft.server.v1_7_R1.ThreadPlayerLookupUUID.run(ThreadPlayerLookupUUID.java:27) [20:30:37] [Server thread/INFO]: GameProfile{id='null', name='turtle2472'} (/192.168.xxx.xxx:49458) lost connection: Disconnected
It wasn't me. Guessing we will have to update to make this issue go away. I'm of course having to let Brad handle that one as I'm not digging into it that much at this moment. I am going to take the time to do server maint I've been needing to though! Brad, text me if you need to get into the server while I have it down. I'll get it right back up for you.
2014-04-09, 21:04
I'm done and the server is back up!
Also, I put it in "offline mode" so it won't try to authenticate to Mojang for now. Less secure, but the only way we are going to be able to play until we upgrade. So get in there an finish up your projects 709!
2014-04-09, 22:02
There are several newer dev versions of Bukkit available through 1.7.5 but none for 1.7.6 or 1.7.7. I'll try to make the time to grab one and upgrade the server tomorrow night. That might help in the auth issues.
2014-04-10, 08:56
I thought I'd get a few morning blocks in, but the server seems to have gone missing (not like yesterday, this is the plain 'ol "Can't connect" message).
2014-04-10, 10:51
Yeah, seems like I'm having a pretty bad issue inside the VM right now. I can't SSH in directly from anywhere other than my local network. I end up connecting to another machine then SSH into the VM. I can't ping from within the VM to anything else.
$ ping 8.8.8.8 connect: Network is unreachable
I'm working on figuring out what's happening in there but at work so limited in the amount of time I can put into it right now. It might have to wait until I get home from work tonight.
In the mean time, I've brought up the FTB machine.
2014-04-10, 11:14
Route was missing the the gateway. I manually added it and things seem back to normal though I can't try the game right now. Give it a shot if you don't mind and post back if there are still issues.
$ route Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface 192.168.xxx.0 * 255.255.255.0 U 0 0 0 eth0 link-local * 255.255.0.0 U 1002 0 0 eth0
[root@anmc ~]# route add default gw 192.168.10.1 eth0 [root@anmc ~]# route Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface 192.168.xxx.0 * 255.255.255.0 U 0 0 0 eth0 link-local * 255.255.0.0 U 1002 0 0 eth0 default 192.168.xxx.1 0.0.0.0 UG 0 0 0 eth0 [root@anmc ~]# ping 8.8.8.8 PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data. 64 bytes from 8.8.8.8: icmp_seq=1 ttl=45 time=26.1 ms 64 bytes from 8.8.8.8: icmp_seq=2 ttl=45 time=25.5 ms
2014-04-10, 11:25
Success!
Thanks for taking the time to figure it out while at work. Much appreciated.
2014-04-10, 11:56
I was also able to log in. Yay!
2014-04-11, 22:29
FWIW, they don't have a patch ready yet for the 1.7.6 protocol changes. As soon as I see one become available, I'll take it for a spin and upgrade our server.
2014-04-14, 16:41
Surprise! Bukkit now has dev builds for 1.7.8. I'll download the latest version later tonight and see if it's good to upgrade on our server.
2014-04-14, 22:10
Woo Hoo! Can't wait to see what the upgrade brings. Now that I'm on the new username settings thing, it'll be another new thing. Maybe even changing the username or something. (Dropping the numbers if possible.)
Also, they just released 1.7.9 for bug fixes and patching stuff.
2014-04-14, 22:43
Countdown for Drew to start whining about not understanding how to upgrade to the new username setting thing in 3.... 2.... 1....
Hey Turtle, how do you do that new username thingy??
Got any instructions?
Countdown for Bruce to be incredulous at Drew's propensity for being baffled in 3.... 2.... 1....
2014-04-15, 01:52
Really? You thought it would take me three ellipses to get to incredulity?
2014-04-15, 18:41
I don't really have directions on this one Drew. I just followed the guide after logging into my minecraft.net account. It's kinda walks you through the process pretty easily.
2014-04-15, 18:52
FYI, I'm about to take the game offline to update it to the bleeding-edge version of Bukkit with the new protocol support. It identifies as 1.7.8, but a 1.7.9 client appears to be compatible with a 1.7.8 server.
If all goes well, this means you should update your Minecraft launcher profile to "Use Latest Version" or "release 1.7.9" before you try to connect again.
2014-04-15, 19:19
So, I'm having to shift around a bunch of data due to the new UUIDs.... we're not back yet, but it's getting there!
2014-04-15, 19:29
Done! I think!
If you have problems connecting, please let me know.
2014-04-15, 20:38
Oh noes!
Edit: FYI, I checked and you do have my UUID correct.
Anyone wondering what your UUID is you can see it in the launcher_profiles.json file in your .minecraft folder.
2014-04-15, 21:11
Me too, same thing.
Oh wells.
Tweet me if you get back in, but I'm going to do some IT work around the house now instead
2014-04-15, 22:26
Dang. I got that the first time too, and I thought I got it sorted out for everybody. I'll take a quick stab at it now, but I have to go to bed soon. Early morning scheduled for me here tomorrow...
2014-04-15, 22:30
Try now?
It looks like something is causing the server to forget its in-memory whitelist. Firing the "whitelist reload" command from the shell seemed to get it back into shape.
I'll put in a temporary cron job to reload the whitelist every, hmmm, 10 minutes maybe?
2014-04-15, 22:32
I just got in!
2014-04-15, 22:42
Someone tell Drew, stat!
2014-04-15, 22:47
I Tweeted it for him.
2014-04-17, 09:33
I broke it.
2014-04-17, 10:05
It wasn't you.
My whole home lost connectivity. I'm guessing it's a service outage but I'm having to troubleshoot via texting to Mrs T. While I'm at work.
The kicker is I was doing stuff there too when I lost connection.
2014-04-17, 10:45
We are back up. I had Mrs T call Verizon and all is well now.
2014-04-17, 11:01
No love here yet. It does look like Verizon is having issues in your area though.
2014-04-17, 11:15
It's bad.
Worse than just that 709, my ONT is bad and has to be replaced. It's scheduled for Saturday 0800-1200.
The ticket is marked for "priority" so it may be done sooner.
I'll be sure to post when I have a connection again that's considered stable. In the mean time, feel free to try to get in at any time, it just might work.
Best VNC server for OS X atomicbartbeans Third-Party Products 3 2007-02-02 00:42
Radius server in Mac OS 10.4 Tiger Server? dougd Apple Products 2 2005-03-20 11:30
