How do you use Dropbox?
jcoley2
Send a message via AIM to jcoley2
2009-11-14, 11:48
Man, I am really not understanding DB. Perhaps it is becuz I was used to Foldershare. I have two computers I am trying to sync some documents folders. I dragged everything I have in my documents folder into the Dropbox folder. It started to sync. Then I realized I probably should try a test folder first, so I dragged everyone of these folders back out of the DB folder and back to documents, but for some reason, they have all gone to Trash?????
I then dragged just one folder into the DB folder, called ABC. On my other computer I see ABC. I have another Folder on my computer called ABC, so I dragged it into DB, thinking it would then synchronized them, but instead it wants to overwrite it.
Please help. I am not understanding how to best set this up.
Now that I got a job, I can buy more Apple products!
2009-11-15, 00:58
Can I do the "ln -s" trick for a file? Specifically the Safari one Brad showed me.
Gargoyle
http://ga.rgoyle.com
2009-11-15, 13:33
jcoley2, first off - the dropbox folder is like any other folder on your HD. So when you are dragging files and folders from the same HD, the default option will be to move said files and folders into the dropbox folder.
All other filesystem rules also apply. So dropping another folder of the same name as an existing one into dropbox will overwrite it. You should treat the dropbox folder like any other on your system.
The files in dropbox will then get pushed up to the DB server and back down to your other machine. Backups, old versions and conflicts can all be viewed on the web interface.
OK, I have given up keeping this sig up to date. Lets just say I'm the guy that installs every latest version as soon as its available!
2009-11-16, 19:01
Does anyone know how this can be done? Please.
2009-11-21, 02:08
Does anyone know if Mac OS's Keychain is encrypted? I'd like to put it in Dropbox too but don't want to if it's not encrypted. I'll get 1Password otherwise, just trying not to spend money on a program I don't need.
MineCraft? mc.applenova.com | Visit us! | Maybe someday I'll proof read, until then deal with it.
2009-11-21, 15:39
Yup. As far as I know, the keychains have always been protected with some level of encryption. Details from Apple on what and how are surprisingly hard to come by, but I did find this:
http://images.apple.com/server/macos...g_20080530.pdf
A keychain is used to store passwords, keys, certificates, and other secrets. Due to the sensitive nature of this information, keychains use cryptography to encrypt and decrypt secrets, and they safely store secrets and related data
http://lists.apple.com/archives/Appl.../msg00017.html
Triple DES, 3-key, EDE. The keychain as a whole is not encrypted; portions of individual keychain items that are sensitive are encrypted on their own. Certificates for example have no sensitive portions and are stored in the clear.
http://web.archive.org/web/200803190...ecurity_TB.pdf
The keychain securely stores user names and passwords. All the password data in the keychain is protected using the Triple Digital Encryption Standard (3DES).
That last PDF is originally from http://images.apple.com/macosx/pdf/M...ecurity_TB.pdf which is now a dead link. Since the Wayback Machine seems to have trouble pulling it, I've mirrored it locally here since it has some useful security advice: http://applenova.com/etc/images/MacO...ecurity_TB.pdf
2009-11-21, 15:46
Also, I ran "strings" on my own keychain file to confirm that the middle quote above from an archived Apple email list is correct: only the passwords and "secure notes" are actually encrypted.
2009-11-21, 15:50
Great document Brad! Thanks. I saw in there that keychain syncing is allowed via iSync but I can't find the option. Has you ever heard of this outside of that document? Are they referring to the MobileMe service being required for that option?
2009-11-21, 15:56
Sorry I didn't catch this earlier.
ln -s sourcefile targetfile
So, if you have file ~/Documents/MyFile and you want to create ~/Desktop/LinkToMyFile, you'd do:
ln -s ~/Documents/MyFile ~/Desktop/LinkToMyFile
Of course, if you're on a Mac, you could simply create an "alias" in the Finder with File -> Make Alias. There are some subtle but important ways symlinks and aliases differ. Since aliases are "a Mac thing", command line utilities don't respect them. Since symlinks are "a unix thing", some Mac apps won't distinguish them from the original file or worse will think they are unrelated separate files, but most modern ones will have them appear like aliases.
Here's how they differ at the command line. In this example, A is the original file (just a blank file), B is a symlink of A, and C is a Mac alias of A.
-rw-r--r-- 1 bradsmith staff 0B Nov 21 15:52 A lrwxr-xr-x 1 bradsmith staff 1B Nov 21 15:52 B -> A -rw-r--r--@ 1 bradsmith staff 47K Nov 21 15:52 C
Neat, huh? The @ symbol means there are extended filesystem attributes on that file, which is to be expected since that's how Mac aliases work. And in the Finder:
Gargoyle
2009-11-21, 16:36
Current version of Dropbox won't sync the extended attribs, so you need to use "ln" in the terminal.
Oh, and you can goto https://www.dropbox.com/votebox and vote for resource fork support.
NosferaDrew
Send a message via ICQ to NosferaDrew Send a message via AIM to NosferaDrew Send a message via Skype™ to NosferaDrew
2009-11-21, 16:55
Interesting link:
Theft tracking method for the mini using Dropbox
2009-11-21, 17:18
Ah, thanks for filling in the gaps! I didn't know that.
2009-11-21, 17:32
That is an interesting link! Certainly one for the bookmarks.
ShawnJ
2009-12-02, 00:59
Anyone have a definitive Dropbox v. iDisk review?
2009-12-02, 08:09
I prefer dropbox because it's just a folder. No mounting drives, etc. I haven't used iDisk in a long while despite the fact I've been a .mac subscriber for years. Not definitive by any means but just my simple reason for using it over iDisk.
If it's not red and showing substantial musculature, you're wearing it wrong.
jdcfsu
2009-12-02, 09:45
Like tori said, the fact that there aren't any mounted drives makes Dropbox much faster than iDisk. It's always connected, doesn't need refreshing, and does everything quickly and behind the scenes. I prefer Dropbox over iDisk as well. The only thing I use iDisk for over Dropbox is public folder sharing. The web address is easier to hand out.
90% of statistics can be made to say anything 50% of the time.
Website | Twitter
2010-01-11, 16:16
So if I upgrade to the most current version of Dropbox is it going to have a problem with my links as I have them? They were created using "ln" in Terminal.
Gargoyle
2010-01-11, 17:06
If you have links in your dropbox folder, they will not be links on the destination machine, they will be a complete copy of the linked folder.
Hopefully this will be fixed soon, since it is stopping me putting my iPhoto library in dropbox!
2010-01-11, 22:44
Guess I'll stick to my current versions then. I was hoping to be able to use the LAN sync functions but I don't mind waiting for them to go to and from the cloud before it propagates.
dmegatool
Custom User Title
2010-01-11, 23:31
Just found a way to do symbolic links in Windows. Pretty handy when you're using Windows and Dropbox.
Just wanted to share. If you guys ever needed.
http://technet.microsoft.com/en-us/sysinternals/bb896768.aspx
Dave Mustaine :"God created whammy bars for people who don't know how to solo."
2010-01-26, 02:22
You know, it just dawned on me that I don't use links in my Dropbox folder, it's my system folders that have links! I'm golden and can update then right?
Why would I want to put links in my Dropbox? As in like the thread's intent, how would that benefit me?
Gargoyle
2010-01-26, 08:21
It might be that you are not doing it intentionally. I wanted to put my iPhoto library in Dropbox, but I can't because it is full of symlinks.
2010-01-26, 11:00
Ok, I didn't thing about iPhoto albums having links. Now it makes sense. Thanks.
noleli2
2010-01-28, 18:33
Originally Posted by NosferaDrew View Post
Ok, so I'm two months late to this discussion, but, while you won't get your whole ifconfig, you can get your IP much more easily from the Dropbox site by hovering over the the i icon in the list of your computers.
ezkcdude
2010-02-11, 18:16
I got an e-mail from Dropbox. Seems they will have an Android app soon:
Have you ever wanted to use your Dropbox but didn't have a computer nearby? Dropbox's mobile website (http://m.dropbox.com) makes it happen. With Dropbox mobile, you can browse and open files in your Dropbox directly from your phone or mobile device's browser.
If you own an iPhone or iPod Touch, download the Dropbox App for an even better experience. It's free!
Do you own a Blackberry or Android phone? Don't worry! We've got plenty more mobile magic coming soon!
Happy syncing!
-The Dropbox Team
2010-02-12, 08:20
I continue to rely on dropbox more and more. It's becoming my default folder for saving documents I create. I figure I don't necessarily need it in the cloud, but since it's so easy, why not? I haven't started moving bigger things up there yet (because I'm stuck on upload speeds that would make angels cry) but I could easily see myself doing that when speeds get fast enough to make it worthwhile.
ezkcdude
2010-02-12, 08:26
yeah, me too. I upgraded to the 50 GB service a couple weeks ago. It just seems so much more useful to always know you're going to be working on the same files wherever you are, and not have to mess with thumb drives or ftp. I basically only use my hard drives for mp3 and movies these day.
kieran
Tweeting @kierankelly
2011-01-17, 13:41
This was the first thread I saw about Dropbox, so I figured I'd just post here.
I don't really use my Dropbox for anything more than just sharing files that are too big to email, so I never paid for it.
They're doing a scavenger hunt type thing right now where you can get an additional 1 GB if you follow the steps. Takes about 20 mins to follow them all, but it's worth it.
Here's the link with how to solve the puzzles.
Just thought I'd share.
2011-01-17, 20:10
I've taken advantage of it and am very grateful for it. I needed the extra space.
LudwigVan
2011-01-18, 00:54
Another public thanks for kieran's note. Though it took me about 35 minutes to work through the puzzles.
Dropbox jdcfsu Third-Party Products 38 2015-08-30 19:42
Dropbox For iPhone Jason Third-Party Products 1 2009-09-30 15:16
DropBox Beta... scratt Third-Party Products 48 2008-09-12 09:41
Amazing Program - Dropbox iThink therefore iMac Third-Party Products 0 2008-03-12 10:46
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
Copyright ©2004 - 2020, AppleNova
