Pretty serious text bug: List text disappears!
2005-05-14, 13:11
I've been starting to use DEVONthink again. It's a pretty nifty app. Anyway, it uses a lot of the frameworks provided by the system for its core functions, including its text stuff. I had made several documents with lists and one day a bunch of my text disappeared! I was ticked, but it turns out it's a 10.4 bug.
TextEdit lists may appear to lose content
mportant: If your TextEdit document list is missing or has been truncated, please note that the content isn't actually gone; it's just not visible to you. However, if you save the document again, the invisible information will indeed be lost.
For example, if you create the following list in a TextEdit document...
- first
- second
- third
... then save the document and open it again, you might only see this:
The note talks about TextEdit but it seems it affects all apps that use the text functions of the OS. I don't know what triggers the loss of text but it's something I thought people should be aware of. Come on 10.4.1!
2005-05-14, 13:17
I was able to reproduce it as well.
Report it!
2005-05-14, 13:22
Report it!
Already known about. How did you reproduce it?
2005-05-14, 13:25
There's also some other strangeness going on.
Make a list. Press return twice so your list looks like this:
• one • two • three non-list item
Now go to list item 3 and press return. You list now looks like this:
• one • two • three • • • non-list item
I don't know if Panther TextEdit did this or not. Anyone running 10.3 wanna check?
2005-05-14, 13:38
Oh, and bug reporter is down. I tried to log in the other day with my ADC account and couldn't. I had to email them to get access but now I can't get in again. It's almost as if they don't want me to report these bugs.
2005-05-14, 14:31
I'm actually wondering if Apple is just trying to imitate Microsoft Word's wholly inconsistent and terribly annoying auto-formatting with lists.
nassau
2005-05-14, 19:40
10.3.4 here... can't seem to do lists at all... or i'm just unable to find it..
2005-05-15, 10:24
Panther doesn't do lists; it's a new feature in Tiger.
2005-05-15, 13:38
One they probably should have left out.
Generating a text list of your iTunes library... Wrao Genius Bar 5 2005-03-10 22:14
