monkey with a tiny cymbal
Here's the IBM release for the cell stuff: http://www-03.ibm.com/chips/news/2004/1129_cell1.html
But this all happened yesterday... and people have hinted at it before. So, what's new today? Last edited by Majost : 2004-11-30 at 09:38. |
Cell supports multiple operating systems, including PC/WS operating systems, as well as real-time CE/Game operating systems. In addition, the Cell processor is scalable and can be utilized in a variety of applications — from small digital CE systems within the home to entertainment applications for rendering movies, to scientific applications, such as supercomputers.
Didn't directly see apple listed... would apple WANT to use this? Why? (with power5's around the corner and of course 970mp) -but perhaps for media creation and testing on a g5/g6? Would this technology make its way into the next gen apple chips? morpheus? - Michael Droste Itunes Link Stop By: TrumpetStudio.com or SaveThePlanetSong.org Some Main Gear: AT4050, Dual 1.8 G4, Logic, Waves Plat, Waves SSL, Tritone, URS, PSP, Zebra, BFD, RND, Sony Oxford, Altiverb... |
16TF in one rack -
I wonder how many chips? $$$$$ 20 chips X let's say $400 per chip (very high) = $8000 + $4000 to $8000 for subsystems and box?(i have no idea) = $16000+- for a 16TF computer! WOW Talk about a shift in power, the virginia tech computer with all of the xserves does a 12 to 14TF or in that range... - Michael Droste Itunes Link Stop By: TrumpetStudio.com or SaveThePlanetSong.org Some Main Gear: AT4050, Dual 1.8 G4, Logic, Waves Plat, Waves SSL, Tritone, URS, PSP, Zebra, BFD, RND, Sony Oxford, Altiverb... |
meh
That cell thing was released yesterday so it wouldn't be what morpheus is talking about. Also, I wonder if the supply problems will only be with the 970fx and not the new 970GX,970MP, and G5 mobile. Morpheus?
giggity Last edited by Quagmire : 2004-11-30 at 18:26. Reason: spelling |
More than one UNIX based OS like LINUX & LONGHORN?
And this too! The processor, code-named Cell, will handle vastly more memory than today's consumer chips as well as <<enable hardware-based copyright protection>> and allow multiple operating systems to run at the same time. It also will feature multiple cores, or logic engines, on a single die. |
Ok, try now:http://power.org/
"Coming together to form the Power.org community are AMCC, Bull, Cadence Design Systems, Chartered Semiconductor Manufacturing, Culturecom, IBM, Jabil Circuit, Novell, Red Hat, Sony Corporation, Shanghai Belling, Synopsys, Thales, Tundra Semiconductor and Wistron." mmm... where is Apple? Shouldn't they be in? Morpheus |
meh
What does this mean for us? Will we get more information from IBM regarding the future of PowerPCs? Last edited by Henriok : 2004-12-02 at 04:48. |
from Power.org, december 2 news
"In a related product development, TimeSys, headquartered in Pittsburgh, PA, announced the availability of its TimeStorm Linux Development Kits for IBM PowerPC 750 FX and GX. Thousands of embedded Linux developers worldwide from a range of industries have chosen TimeSys solutions to streamline the development, customization and validation of homegrown or commercial Linux-based embedded systems." 750 GX PM in january? Morpheus.... |
In fact I wrote "750 GX PM" but it would have been better "750 GX Mac". I've always tought the GX variant of the 750 was nothing but vaporware! |
You might think of the 750VX that's pretty vaporous. Apple skipped the 750GX and wen't directly to the G4, and that's probably why we havn't seen much of it in the Mac related press. It has larger cache than the 750FX and is clocked a bit higher and supports a 200 MHz bus. It's still a 130 nm part though and I'm amazed that we havn't seen a 90 nm 750 class processor yet. It'd be a killer in the embedded market. Last edited by Henriok : 2004-12-02 at 04:58. |
Not bad... I've made 4 posts and 3 of them are total bullshit... :-))) nice record! |
Considering we know practically nothing about the Cell except that at least some part of it uses the POWER ISA, it is a possibility. The Cell's vector processors aren't really like AltiVec -- they are seperate cores with a (presumably) different ISA. AltiVec is an extension to the PowerPC ISA and therefore runs as part of a PowerPC core.
If that isn't clear, try this: a processor core (or SMT thread) follows its own stream of instructions that controls what it does. The instructions that it understands are its ISA (instruction set architecture), i.e. a list of specific instructions that tell the core what to do. Adding AltiVec created the ability to insert a new set of instructions into the stream for the G4/G5 PowerPC core. Adding Cell vector processors adds additional cores that each have their own stream of instructions which they execute at the same time as the POWER core. The instructions found in the streams for the vector processors are different than those found in the POWER core's stream, just like a POWER core and an x86 core have different instructions in their streams. It is possible that IBM/Sony/Toshiba used some portion of the existing POWER instructions, but I doubt it as that would serve little purpose -- either a core understands the whole stream, or it will crash while trying to execute it (or emulate it really slowly). What Cell vector processors and PowerPC AltiVec (and Intel's SSE/SSE2/..., and most modern GPUs) do have in common is 128-bit registers which can hold, among other things, 4 32-bit floating point numbers at a time. These registers are used with SIMD instructions, which stands for "Single Instruction Multiple Data" -- i.e. a single instruction does the same thing to all the data elements found in the register (i.e. the 4 32-bit floating point numbers). This is as opposed to conventional instructions which typically do one thing to one piece of data, i.e. a register that holds 1 value. I ask for the pardon of technical readers for glossing over details and over-generalizing things. |
In any case, Programmer's post here is certainly more comprehensible (to me) than some others he has posted and, for that matter, some of unixguru's posts. I note that one of the 'guru's recent messages concluded as follows Quote:
I suppose that we have people of all ranges of technical knowledge here on AN. I've been meaning to post a poll to try to get a better idea of "who we are", at AN, in that regard. I'll get around to it one of these days. When there's an eel in the lake that's as long as a snake that's a moray. |
Ehh, the guru post was just a cut-n-past of the output from the dmesg command or boot.log file (some Linux distros have it). Nothing special except that this is some interesting hardware that just about nobody else has their hands on. Most of it isn't terribly relevant to anything we'll see in a Mac.
Page 11 of 23 First Previous 7 8 9 10 [11] 12 13 14 15 Next Last |
Opinions on the IBM Cell Processor article | micmoo | Speculation and Rumors | 14 | 2004-07-20 22:57 |
Apple releases updated Power Mac G5s | staph | Apple Products | 43 | 2004-06-09 13:20 |
