Page 10 of 21 First Previous 6 7 8 9 [10] 11 12 13 14  Next Last Thread Tools
2017-09-29, 13:19
Server ist kapüt!
2017-09-29, 13:21
I'm in right now. It is up... Wonder if my IP changed or something.
IP looks good. What happens when you try to connect?
Edit: Testing from my web server that is outside of my firewall with a hosting company:
[turtle@web-nyc3 ~]$ telnet anmc.dyndns.org 25565 Trying 71.120.224.76... Connected to anmc.dyndns.org. Escape character is '^]'. ^CConnection closed by foreign host. [turtle@web-nyc3 ~]$ telnet mc.applenova.com 25565 Trying 71.120.224.76... Connected to mc.applenova.com. Escape character is '^]'. ^CConnection closed by foreign host.
Both tests show the server accessible still.
2017-09-29, 13:46
Man, there's zero connection on my end, and our intrawebs is working just fine.
Hmmmm
2017-09-29, 13:50
Go to Terminal and try to telnet like I showed above. I'd say try pinging but my firewall drops pings.
Edit: These two sites show I'm up too. Wonder why you can't connect now. Let me know how the telnet test goes.
You can also try
dig anmc.dyndns.org
and let me know what IP it gives you.
Note, for the sake of troubleshooting I'm having you use my dynamic hostname rather than mc.applenova.com. While that name points to the dynamic hostname, I want to remove at least one variable from the troubleshooting.
2017-09-29, 14:14
I just rebooted my computer and now I'm on.
Weird.
2017-09-29, 14:19
That happens when you live in a Windows world.
2017-10-02, 16:37
Serve is down at the moment. Crash on the host machine. Working to resolve.
2017-10-02, 19:24
Sorry if you were on. Forced server reboot again. This should conclude issues for getting on the server tonight.
2017-10-10, 20:18
host machine for the MC server just locked up. Rebooting now and it should be back up shortly.
2017-10-14, 21:44
Host machine issues again. Will be back up shortly I hope.
I'm prepping to update to the newest OS on there now so I wasn't planning to reboot yet. Sorry if you were on and got dropped.
2017-10-25, 17:12
In the not to distant future I'm going to be shutting down the server in preps to move it to it's new home. I have a new host machine I just finished building and need to pull some hardware (RAM) out of the one it is currently running on. I should only be down for about 30 minutes or so during that time as I just need to power down the host and remove the two sticks and close it back up.
Later I'll post about the changes made when I'm getting it moved to the new ESXi server. I still have a bunch of configuration to do on it so that will be within the week most likely.
2017-10-25, 17:47
Did you kill it?
2017-10-26, 07:39
Is it happening? I'm getting: io.netty.channel.abstractchannel$annotatedconnecte xception: connection refused
2017-10-26, 12:10
Yep. Me, too.
Edit: Maybe Turtle got sucked into a wormhole?
2017-10-26, 15:46
Sorry guys. I didn't get the notice that there was a post on here and totally missed it.
The server suffered from an Out of Memory error and Java was killed. I have just restarted the server and hope it resolves it. There was a Java update that I recently did that could be why the server now want more RAM. I can allocate more if needed. Please PM me if you post on here and here nothing from me.
Sorry for the delay guys.
Edit: Hoping the reboot fixed it. I'm logged in now and there's plenty of RAM free:
$ free -m total used free shared buff/cache available Mem: 3790 1013 2539 8 237 2538 Swap: 3967 0 3967
2017-10-26, 16:56
Seems to be playing well.
Thanks
2017-10-30, 10:12
In the not too distant future I'm going to be moving the MC server to the new ESXi server I just built, Hildegund. This will require that I shutdown the VM initiate the migration and then bring up on the new host. Make a few adjustments and then go live. I'll try to make sure no one is on and it will likely happen first thing in the morning for me to impact the least players.
I really don't know how long this process will take, so I'll post here when I'm about to begin.
If catastrophe happens, I'll just turn it back on here on it's current host, Volstagg, and try again another time.
2017-10-30, 13:34
Are you killing it?
2017-10-30, 13:39
I was on, got sketchy bumped again. Everything just kind've stops. I'm able to walk around for a bit looking at unspeaking and frozen sheep, parrots, whatever.... then black. The past few times I've lost everything, but maybe this was just a machine freeze.
2017-10-30, 13:41
That is because we just lost power to my house. It will be back up once we get power back. Since it was a drop, please check inventory and such when you get back in.
2017-10-30, 14:11
Looks like power is coming back on now. The server should be back online shortly while all the gear in-between comes back. I'm not sure that Volstagg ever dropped so we might not have lost anything. I was able to do a backup at 14:45 or so while it was still up so we should be good there at least.
2017-10-30, 14:43
I just logged into the game (power came back) and it looks good from my perspective. Give it a shot and let me know if you need goods. I will note that the game server never lost power. The battery backup held strong for it.
2017-11-03, 08:12
Server crash? I was on for just a sec and got fro-zoned.
2017-11-03, 13:24
Looks like it was an out of memory kill again. I've restarted the server now. I'm going to move it to the new server this weekend most likely. This will allow me to devote more resources to it and hopefully stabilize it better.
2017-11-03, 14:26
Oooooo, stability! Sounds delicious.
2017-11-05, 12:55
Server is down while I backup, move and bring up on the new host.
2017-11-05, 18:45
This move is taking WAY longer than I expected.
2017-11-05, 20:34
Finally up on the new server. Give it a run through and let me know if there is an issue. I'm not feeling great so I won't be at work in the morning. PM me if there is an issue when you try to get on as well as posting here.
2017-11-16, 18:30
Did it go uck?
2017-11-16, 19:56
Looks like it. PM turtle?
