Apple introduces Boot Camp (Boot Windows XP on Mac)!
Page 14 of 14 First Previous 10 11 12 13 [14]  Thread Tools
tacvbo83
2006-04-10, 20:04
Just noticed 2 things after BootCamp removal.
1) The sound that would go away when either PhotoBooth was turned on or when my MBP was plugged in to a power source now just goes away with opening PhotoBooth. I guess Apple will have a fix for this in the future, hopefully.
2) A loud fan-like noise came up all of a sudden going down minute by minute until I could just hear it alittle. This was the same noise that made me take off XP in the first place. Probably I just freaked out and it is normal for that loud fan to come on since the MBP does get hot. Does anyone else get this? If it is normal, I shall try BootCamp again since I have not heard any bad things about it. EDIT: well I guess it is normal because the loud noise is gone for noe
turbulentfurball
Right Honourable Member
Send a message via ICQ to turbulentfurball Send a message via AIM to turbulentfurball Send a message via MSN to turbulentfurball
2006-04-10, 20:29
This may not be relevant, but when XP boots on my laptop, Compaq; not Apple, the fans go to their highest speed until booting is complete. This happens well after the BIOS screen, once booting is underway. Perhaps this is a default thing for Windows. I really don't know.
clintonintern
2006-04-11, 14:02
Now that Boot Camp is in the wild and successfully put through its paces, I was curious to know what everyone would install on their XP partition and why. For me, I'm going with Microsoft Office and Photoshop cause I need it for work.
Anyone else?
Yanked cause people think its spam...we can just enumerate.
1) office
2) photoshop
3) hl2
2006-04-11, 14:21
Anyone else?
Poll on Blab List
This sounds like spam.
Gargoyle
http://ga.rgoyle.com
2006-04-11, 14:44
Both Office and Photoshop work fine in OSX!
Half-Life 2, Already installed - runs very nice and looks great at 1680x1050 Possibly Visual Studio 2005. To make it perfectly clear, only stuff I can't run under OSX.
Oh, and for now - I have already removed Boot Camp and returned to just OSX. Why? Because I have top of the line (almost) PC gear sat here. When it next comes time to replace it, I won't. I'll just dig out Boot Camp.
OK, I have given up keeping this sig up to date. Lets just say I'm the guy that installs every latest version as soon as its available!
BlueRabbit
2006-04-11, 17:47
And as Steve Jobs has shown us so many times, Photoshop is much, much faster on the Mac.
julesstoop
2006-04-11, 17:51
Especially when ran in Rosetta.
tacvbo83
2006-04-11, 18:42
Weirdest thing happened right now when starting up my MBP. It stayed on the gray screen more than usual to then flashing an Apple(like normal), then a box with a "?", and then back to normal with the Apple started. I might be wrong I after taking out BootCamp I have been noticing several issues here and there like this one.
bassplayinMacFiend
Banging the Bottom End
2006-04-11, 19:04
Go into System Preferences (on the Apple menu). Then click the Startup Disk preference pane (in the System row). Manually select the OS X option then click Restart.
I ran into this when I was switching between Jaguar on an external disk and Tiger on the internal disk. It tried to find the external disk and couldn't (hence the ? icon), then found the internal Tiger install and booted that. Once I used the Startup Disk pane to point to Tiger and restarted, all the ? icons at startup went away.
2006-04-11, 19:32
I told you, tacvbo83, that you shouldn't have tried this. Sorry. It had to be said.
tacvbo83
2006-04-11, 20:45
thanks bassplayinMacFiend, works fine now
tori...it is not like I am a begginner with computers, i did everything to the letter and just tried to install norton
Apple in Ten Years Chinney Speculation and Rumors 57 2008-01-29 20:34
Does the Intel Processor make the mac better? HTee Speculation and Rumors 62 2005-11-15 20:51
Apple releases updated Power Mac G5s staph Apple Products 43 2004-06-09 13:20
Apple livid over Toshiba iPod leak curiousuburb Speculation and Rumors 11 2004-06-05 17:49
