MC: AppleNova is now running Feed the Beast's Direwolf20 Modpack!
Page 5 of 14 Previous 1 2 3 4 [5] 6 7 8 9  Next Last Thread Tools
2013-03-22, 14:53
That's fine. Thanks for looking at it.
2013-03-22, 19:51
It must've corrupted me as I entered the portal. I've tried turning off what extras I could and deleted some of the player files on my machine, but no dice.
This is what the Console says (in red (!)):
013-03-22 20:47:18 [INFO] [STDERR] t: Ticking screen 2013-03-22 20:47:18 [INFO] [STDERR] at net.minecraft.client.Minecraft.l(Minecraft.java:1544) 2013-03-22 20:47:18 [INFO] [STDERR] at net.minecraft.client.Minecraft.J(Minecraft.java:846) 2013-03-22 20:47:18 [INFO] [STDERR] at net.minecraft.client.Minecraft.run(Minecraft.java:771) 2013-03-22 20:47:18 [INFO] [STDERR] at java.lang.Thread.run(Thread.java:680) 2013-03-22 20:47:18 [INFO] [STDERR] Caused by: java.lang.NullPointerException 2013-03-22 20:47:18 [INFO] [STDERR] at cpw.mods.fml.common.network.EntitySpawnPacket.execute(EntitySpawnPacket.java:175) 2013-03-22 20:47:18 [INFO] [STDERR] at cpw.mods.fml.common.network.FMLNetworkHandler.handleFMLPacket(FMLNetworkHandler.java:102) 2013-03-22 20:47:18 [INFO] [STDERR] at cpw.mods.fml.common.network.FMLNetworkHandler.handlePacket250Packet(FMLNetworkHandler.java:67) 2013-03-22 20:47:18 [INFO] [STDERR] at ayh.a(NetClientHandler.java:1483) 2013-03-22 20:47:18 [INFO] [STDERR] at di.a(SourceFile:59) 2013-03-22 20:47:18 [INFO] [STDERR] at cg.b(TcpConnection.java:458) 2013-03-22 20:47:18 [INFO] [STDERR] at ayh.d(NetClientHandler.java:240) 2013-03-22 20:47:18 [INFO] [STDERR] at ayk.c(GuiConnecting.java:49) 2013-03-22 20:47:18 [INFO] [STDERR] at net.minecraft.client.Minecraft.l(Minecraft.java:1537) 2013-03-22 20:47:18 [INFO] [STDERR] ... 3 more 2013-03-22 20:47:28 [INFO] [STDOUT] Stopping! 2013-03-22 20:47:28 [INFO] [STDOUT] SoundSystem shutting down...
2013-03-22, 20:43
I moved your player data 709 so try to get logged in again and see if you can succeed. Brad or I can revert you back to the old player if needed, but I'm pretty sure this should do the trick.
2013-03-22, 21:30
Damn! That was a success afa getting back in, but as soon as I entered my portal in the nether I crashed again - and now I'm getting the same thing.
Looks like I'll have to go the long way around and tear down that damn thing and build anew. Would you mind deleting my data again?
What a pain. I have no idea why it's decided to act up.
2013-03-22, 22:20
Done. Hope it sticks for you this time.
2013-03-22, 23:44
Thanks for jumping on that fix, turtle. I had to run some errands before coming home, and then I had some work I needed to finish before I could get around to this.
2013-03-23, 08:37
I think I figured out what's going on.... I placed a scarecrow right as I was entering my portal and crashed. After Googling a bit I found this thread saying that scarecrows are a known problem with ExtraBiomesXL. Fuuuu.
I'm able to log in now at least (thanks T ) but as soon as I get near my base I crash out again. Any chance we can change the entity# for scarecrows? Preferably not to a ghast or anything destructive as the scarecrow is inside my base.
It didn't occur to me before that it might be a block that I placed - I just assumed it was a bad portal jump.
Anyways, STAY AWAY FROM SCARECROWS! They will fuck your life up.
2013-03-23, 10:17
Glad I could help out. I've moved your player dat file again. You should be able to log in. I would have gotten to it sooner, but I slept in and it felt good! Not sure how to change a scarecrow. Might have to let Brad handle that one. Maybe we could kill your whole chunk of Nether...
2013-03-23, 10:46
ok... turn off soulshard plugin on the server...
edit maybe not... i thought that that would fix it... but this is an extrabiomes problem?
2013-03-23, 10:46
It's not that easy, unfortunately. I may have to delete the whole chunk if I can't find the entity with some kind of NBT editor. I'll give this a shot today. Exactly where are you (nether or overworld? coordinates?) when it crashes?
I'll also see if it's possible to disable crafting of scarecrows to prevent this kind of thing from happening again.
2013-03-23, 10:48
Is that the cause of the scarecrow problem?
Also, won't disabling a plugin after entities from that plugin already exist in the world lead to a corrupted world?
2013-03-23, 10:53
well this is a client side bug -- a couple of things i have tried haven't worked...
which is to say i have become a victim of grey's scarecrow....
2013-03-23, 11:09
here's where it says i am...
x=-1893.00, y=122.12, z=-1445.00
do... remove me before you delete the chunk. the other option is nuking it.
2013-03-23, 11:09
The base is in the Overworld @~ -1895 -1445. I really don't want to delete the chunk as I've just finished moving all my mining loot from the treefarm over there. Worst case I'll let it sit for a while and hope the next FTB update fixes it.
I got within 100 blocks of it today on foot before it crashed - probably right as it tried to load the chunk.
Disabling scarecrows is probably a good idea. I figured all this stuff was tested before-hand on their end, but apparently there's a major bug here.
As I was trying to figure out what was going on this morning I noticed people saying the scarecrow entity has either ID 12871 or ID 13127:
A difference of 256 with item id's is noting to worry about in the first place as long this doesn't cause a collision (Minecraft internally subtracts a 256 from the configured id at some places, so some mod authors are adding a 256 to compensate for before registering their items)
2013-03-23, 11:12
That's likely the exact location of the scarecrow inside my base. NO nukes plz! Too much work has gone into it.
2013-03-23, 11:41
I'm diving into investigating/attempting repairs now...
2013-03-23, 12:55
If either Brad or Turtle could pull my avatar out of "Dark night of the Scarecrow" that would be great.
2013-03-23, 12:57
I'm shutting down the world now so I can more safely edit these chunks.
Basically, this is me right now. It would be too perfect if the patient's name was Lenny instead of Bob.
http://youtu.be/v2XkTIYhQC8?t=18s
2013-03-23, 13:01
Oh man... what a clusterfuck placing a simple scarecrow turned out to be. Thanks again for the surgery Brad.
2013-03-23, 13:13
So, uh, I think I fixed it...
But, well...
709, was your hut filled with oil before?
I swear I didn't do that intentionally!
2013-03-23, 14:23
LOL!! He could probably use a few chickens too!!
2013-03-23, 14:55
drew... your portal... its kinda awkward on that hall... perhaps build a room around it, so you don't have to run through it to get past?
2013-03-23, 15:25
But, well...
All is good thanks to Brad's skillz. Thanks again!
The oil thing was... weird. Apparently "new" blocks don't translate very well (my overhead lamps turned into oil blocks...wtf?), but everything's fine now.
2013-03-24, 16:59
Oil's well that ends well
It has been explained to me that you don't have to build on the EXACT duplicate coordinates, so I will re-engineer my portal when I get a chance. I apologized in the other Bad Wolf thread, but will apologize here as well for the inconvenience of my nether portal
2013-03-24, 19:48
I moved your portal for you. You might want to add a sign to it though. I basically just turned it to the side so we all run past it instead of through it.
2013-03-24, 23:11
Thanks T.
My dad was sick this weekend and we ended up taking him in for emergency surgery Saturday night. He's recuperating in ICU and I've only been able to surf net and make comments from my phone. I thought about going in there to do it tonight but I need to get some sleep.
2013-03-25, 07:25
Sorry to hear the news. Hope your Dad turns out just fine from this though.
2013-03-25, 08:58
Thanks T. Hope to have him home by Friday.
I have to brag some.
This is the first world where I have gone down to mine intentionally for diamonds by myself. In one other world I found some in a ravine, but we had a party of explorers. This time it was me all by myself, and my very first haul netted 13 diamonds!!!! It was a milestone for me!
2013-03-25, 15:06
My goodness do they grow up fast...
2013-03-25, 18:26
Wow, that's good for you Drew! Now you need to stay down there and get more! Plus, add torches and you'll see how safe it really is.
Is your Mac hungry ? Feed it ! Aquafadas General Discussion 6 2007-11-30 19:56
10.5 RSS Feed question ericarthur Apple Products 1 2006-09-28 13:13
RSS Feed for AN turtle Feedback 4 2006-07-17 19:21
Safari and Shiira can't see my RSS feed turbulentfurball Programmer's Nook 3 2006-05-15 03:03
RSS Feed on the front page... Paul Feedback 9 2005-05-01 02:26
